Foundation settlement - Pressure Vessels
Posted: 22 Feb 2026, 18:47
by ivani1
Does any of the API inspection code of pressure vessels /heat exchangers calls for foundation settlement check? If yes, by what means? To perform some survey with recorded readings?
Re: Foundation settlement - Pressure Vessels
Posted: 23 Feb 2026, 07:45
No there is no mandatory /listed requirement in API 510 pressure vessel inspection code to actually perform a settlement survey. In case of storage tanks, applying API 653 yes, it is applicable that settlement survey is performed.
Posted: 23 Feb 2026, 08:51
by ivani1
Alright, what are the requirements mentioned in API 653? Is there any particular frequency mentioned to perform settlement survey?
Posted: 22 Mar 2026, 13:52
According to Section 12.5 and Annex B of API 653, settlement must be evaluated during every internal inspection (Out-of-Service). If a tank shows visual signs of distress while in service, a survey is triggered immediately.
