Foundation settlement - Pressure Vessels
Does any of the API inspection code of pressure vessels /heat exchangers calls for foundation settlement check? If yes, by what means? To perform some survey with recorded readings?
Re: Foundation settlement - Pressure Vessels
No there is no mandatory /listed requirement in API 510 pressure vessel inspection code to actually perform a settlement survey. In case of storage tanks, applying API 653 yes, it is applicable that settlement survey is performed.
Alright, what are the requirements mentioned in API 653? Is there any particular frequency mentioned to perform settlement survey?
According to Section 12.5 and Annex B of API 653, settlement must be evaluated during every internal inspection (Out-of-Service). If a tank shows visual signs of distress while in service, a survey is triggered immediately.
