Use of CS instead of KCS
Posted: 19 Dec 2010, 19:21
by kamran
Consider the following situation:
Working Fluid: Ammonia
Operating Temperature= 33 degrees Celcius
Recommended material= Killed Carbon Steel (can withstand up to -45 degrees Celcius)
At some points Carbon Steel has been used (cannot go below -10 degrees Celcius).
It is realistic to expect that temperatures in the range of -20 and below would be scaled during start-ups and shut-downs.
It is worthy to operate the line for around 45 days with some CS spools?
Please advise.
Kamran
Re: Use of CS instead of KCS
Posted: 20 Dec 2010, 05:15
You must have known the phenomenon of Brittle Fracture associated with low temperature operation of steels due to reduced toughness.
If your MDMT is coming out to be -10 deg C and the carbon steel in question is not impact tested, you cannot go below -10 deg C in any case as brittle fracture phenomenon is always faster than a ductile fracture. Even at lower stress values, brittle fracture can occur.
What's the stress ratio in your case as per ASME B31.3?
Posted: 20 Dec 2010, 09:20
by irish
What's the CS material? ASTM designation?
Piping size and operating pressure?
Carbon steel pipes in API 5L gr. B and A106 gr. B can withstand temperature up to -29 deg C as per Curve B of Fig. 323.2.2A
