commissioning and pre commissioning
Posted: 08 Nov 2010, 04:59
by westdeap12
What critical matters and things do i need to bother during pre commissiong and commissioning of a esterification plant. I am a process engineer. so, for mechanical and piping work, i am not sure. I have to liaise with the commissioner to sort out all the problem. Please advise.
Re: commissioning and pre commissioning
Posted: 08 Nov 2010, 19:11
by qaisarabbas
You are talking about a vast topic. You may find your interest in API-700 (Checklist for Plant Completion).
Posted: 09 Nov 2010, 05:51
by tosif
In general, as far as
Owner Process Engineering review scope is concerned, you will be responsible for following (pre-com);
- Verification of as-built P&ID
- Vessel internal inspection before final box-up
- Control loop verifications (soft loop testing)
- Reduction of catalyst (if present and required) under OEM presence
- Verification of flow meters (orientation, location and metering factors etc)
And for commissioning;
- Pre-Startup-Safety-Review cycle (PSSR)
- Performance test runs of all equipments (machines, distillation columns, furnace, mixers, exchangers, catalyst, gas turbines etc)
- Verification of overall plant performance including energy index and production capability
- Plant smooth operations at all guaranteed production loads, with respect to any design limits breach.
- Development of new KPIs (Key Performance Indicators) in addition to OEM provided KPIs, to monitor plant performance in more precise and accurate way.
For a Commissioning Process Engineer (EPC) then your responsibilities will be entirely different. That mainly includes the compliance of contractual numbers, by any means necessary.
