Major applications of P5 alloy
Posted: 25 Jun 2026, 18:38
What are the major applications of P5 alloy in petrochemicals industries?
Which piping system normally they are particularly used in?
Re: Major applications of P5 alloy
Posted: 27 Jun 2026, 10:47
Mainly used to transport hydrocarbons, gases, and other fluids at elevated temperatures and pressures. For heat exchangers, utilized in shell and tube configurations and furnace components where materials must resist thermal cycling and heat.
It is essential for handling processes that are subject to heavy scaling, hydrogen attack, and sulfidation.
Utilization in furnace & coker heater tubes, Fluid Catalytic Cracking Unit (FCCU) risers where standard carbon steels would degrade.
Also in vacuum distillation transfer lines which transports highly volatile, extremely hot petrochemical outputs in refining trains.
Posted: 28 Jun 2026, 09:13
Typical services include:
Radiant coil outlet piping
Convection section piping
Transfer lines from fired heaters
Hot hydrocarbon piping
High-temperature steam piping
Typical operating temperature:
450–650°C
Can be used higher depending on design code and stress calculations.
Posted: 28 Jun 2026, 12:00
by irish
P5 is considered a very important Cr-Mo alloy for high-temperature piping. It fills the gap between carbon steel (which lacks adequate high-temperature performance) and higher-alloy Cr-Mo materials such as P9 (9Cr-1Mo) or P91 (9Cr-1Mo-V-Nb), which are chosen when even greater creep strength and oxidation resistance are required.
Posted: 05 Jul 2026, 14:49
Thank you.
I was thinking about the same.
irish wrote: 28 Jun 2026, 12:00
