Piping Design Engineer - At 10 years Experience
What are the minimum things to know for a piping design engineer at 10 years of experience in a petrochemical unit?
Re: Piping Design Engineer - At 10 years Experience
Here are the minimum core competencies required at this career stage (reference, a JD for a Senior Piping Design Engineer, not including everything):
1. Advanced Codes and Standards
ASME B31.3 (Process Piping): This is your primary mandate. You must understand fluid service categories (Normal, Category D, Category M, High Pressure) and how they dictate NDT (Non-Destructive Testing) requirements.
ASME B16.5 & B16.47: Understanding flange ratings, pressure-temperature alignments, and the nuances between Series A and Series B flanges.
API Standards: Familiarity with API 610 (Centrifugal Pumps), API 661 (Air-Cooled Heat Exchangers), and API 520/521 (Pressure-relieving systems) is essential for equipment piping.
2. Stress Analysis & Flexibility
While you might not be a full-time Stress Engineer, a Lead Designer must intuitively understand:
Thermal Expansion: Predicting how a system will move at operating temperatures (200°C to 500°C+).
Nozzle Load Limits: Ensuring the piping doesn't compromise the integrity of expensive equipment like pumps or turbines.
Support Philosophy: Designing the difference between a "Restraint," a "Guide," and an "Anchor," and knowing when to use Spring Hangers for vertical expansion.
3. Materials Selection & Corrosion
In petrochemicals, the "fluid" is often your biggest enemy. You should know:
Material Classes: When to move from Carbon Steel (A106-B) to Stainless (304/316) or Chrome-Moly (P11/P22) for high-temp hydrogen service.
Corrosion Allowance: How to incorporate thickness losses into the design life of the plant.
Piping Specification (Pipe Class): The ability to develop or audit a Piping Class based on a Process Data Sheet.
4. Constructability and Maintenance (The "Human" Element)
A 10-year veteran designs for the person with the wrench, not just the 3D model:
Operator Access: Ensuring valves are at hand-wheel height and instruments are readable from grade or platforms.
Rigging & Maintenance: Providing "drop-out" spools for pump removal and ensuring there is enough crane access for heat exchanger bundle pulling.
Tie-ins: Mastery of "Hot Tapping" procedures and Brownfield integration (connecting new piping to existing live headers).
5. Interdisciplinary Coordination
You are the "hub" of the wheel. You must be able to spot-check:
Process (P&IDs): Identifying missing vents, drains, or bypasses that the process team might have overlooked.
Civil/Structural: Determining if the pipe rack can handle the weight of a liquid-filled line (Hydrotest weight vs. Operating weight).
Instrumentation: Understanding the "Straight Run" requirements for flow meters (Orifice plates, Vortex, etc.) to ensure accurate readings.
I may not have followed your query properly but I would like to say that at the 10-year mark, a Piping Design Engineer typically transitions into a Senior or Lead role. While the first five years are about mastering the tools (SP3D, E3D, Caesar II) and the codes, the next five are about accountability, checking, and interdisciplinary integration.
You are no longer just responsible for your own "line list"; you are responsible for the technical integrity of the entire piping system and the productivity of the junior team.
Rest what has been covered is all good, and I would like to add the following as the core competency:
Understanding of piping design codes:
ASME B31.3 – Process Piping (mandatory).
ASME B31.1 – Power Piping
ASME VIII – Pressure vessels connection knowledge.
API standards – API 650, 620, 579 (fitness for service).
ISO/EN equivalents if working in international projects.
At 10 years, in my opinion, you are expected to interpret codes, not just follow them — make judgment calls when conflicts arise.
The very basic one items that should mandatorily be considered.
arcpro wrote: 01 Apr 2026, 14:46 Rest what has been covered is all good, and I would like to add the following as the core competency:
