Oxygen content - Welding SS for Highly Corrosive Service
Any limits on oxygen content before welding stainless steel to be put in highly corrosive service like ammonium carbonate?
If yes, then what are the available references to follow?
Re: Oxygen content - Welding SS for Highly Corrosive Service
Ammonium carbonate / carbamate type services are typically treated as highly aggressive in many plants, so it’s reasonable to set 50 ppm as your hard “go/no-go” before welding, not just “try to.” (Final acceptance should still be based on your corrosion / NDE / spec requirements.)
Look for something even more specific in OEM manuals for welding of materials in these services. Even closer recommendations, you can find there.
What are the materials you have been using?
Has this been referenced in any of the standards, this I am looking forward to.
I would say AWS D18.2 is the most cited guide for heat tint levels in stainless steel piping. It provides a visual scale (1 through 10) to determine acceptable oxidation. For ammonium carbonate, you are typically aiming for Level 1 or 0.
Thanks mechcolor, will pick that.
Any references other than this AWS D18.2?
