Mill tolerance other than 12.5%
Posted: 15 Feb 2026, 11:22
In what cases, piping mill tolerances are set to other than default 12.5% value?
Re: Mill tolerance other than 12.5%
Posted: 20 Feb 2026, 05:09
There are cases in procurement where tolerance other than a default value is considered but within +/-12.5%.
Like they can go to a tight one -10%.
ASME B31.9M specifies to be -10%, as that is expensive, SS.
Posted: 25 Feb 2026, 10:20
by neo
mechcolor,
Tolerance would not be defined by ASME B31.9.
Actual tolerances are governed by the material specification, such as:
ASTM International ASTM A312 (seamless & welded SS pipe)
ASTM A358
ASTM A790 (duplex SS)
Posted: 02 Mar 2026, 17:55
Thanks all.
