Piping Clamp Design Calculations
Do someone has the good reference or a working sheet for piping clamp design calculations?
The cases are to arrest the piping leaks, both from the main piping and from flanges.
Re: Piping Clamp Design Calculations
Check this out, this should help.
447508111-Boxup-Clamp-Design.xlsx
The sheet is useful.
Thank you.
ivani1 wrote: 06 Sep 2025, 09:05 Check this out, this should help.
