Pipelines Material Selection
A brief and nice article on "General Material Selection Guidelines for Oil Gas Industry Pipelines" by K. Nalli & Mott MacDonald & Co LLC, published in Pipeline & Gas Journal (2009).
Tells a deal on all pipeline types, depending upon their functionality, corrosion threats, materials generally used...
Abstract is here as under:
"This article presents a few tips on pipeline material selection methodology based on a rational approach drawn from oil and gas industry practices and field experiences. There will be no dwelling on any specific selections since the pipe material chosen purely depends on the operating envelope that includes such parameters as type of fluid, fluid compositions, flow, pressure and temperatures. The subject is vast and every selection is determined case by case. However, this is mainly a look at some general guidelines..."
Hope you enjoy the read.
General-Material-Selection-Guidelines-for-Oil-Gas-Industry-Pipelines.pdf
