Incident Investigation Guidelines
Part of an incident investigation team to support from process /operations side on loss of primary containment incident. Can someone share some pointers where and show should I be adding value?
Re: Incident Investigation Guidelines
Check out the attached file. Will definitely help.
Check out the attached document.
Some leads within.
Very concise guidelines.
Thanks you shared.
octane wrote: 28 May 2025, 16:26 Check out the attached file. Will definitely help.
This should be kept as a pocket guide while performing any investigation.
I like the way the identification of protection systems has been referenced.
Why tree has been given some very good recommendations as well.
ivani1 wrote: 28 May 2025, 16:49 Check out the attached document.
Some leads within.
