"Trim"
"Trim"
Occasionally i have seen that in P&IDs , inside equipment there is written word "Trim" what is the meaning of that . kindly elaborate in detail...?
Re: "Trim"
In P&IDs, trim is just an additional information added to any equipment or piping like the specification to which this belong to or insulation, tracing requirements applicable on it.
ibrahim
Re: "Trim"
Post by ibrahim »
"Associated trim" is a term referred to all associated minor accessories of any vessel like vent valves, drain valves, instrument bridles, etc. In general P&ID also contains information regarding piping material, insulation requirement and other related to the trim. There accessories are basically part of vessel / exchanger mechanical drawings, in detail. Hope you get the point.
Re: "Trim"
Thank you for your response .
Can i see the Enlarge picture of the "Trim" so that it could help clarify us better??
