Pipe exposed to hydrogen flame
Posted: 07 Dec 2010, 05:54
Recently, we had an incident at our Plant when a thermowell got detached from a Syn Gas piping and the gas caught fire. The flame completely damaged the nearby insulated piping and the bare piping then exposed to the flame for about 25 minutes.
The nearby piping is in different materials including A333 Gr. 6, A106 Gr. B, A335 P11 and A335 P22. We have visually examined the piping and there are some apparent marks of flame exposure plus burned insulation / cladding.
In order to ensure the mechanical integrity of piping, we have taken hardness readings on the piping which was directly impinged by flame. The hardness reading for that specific piping in A333 Gr. 6 material is coming out to be 80 BHN which is a too low number. Unaffected metal hardness is in the range of 140-160 BHN. Based on this hardness check, we are planning to replace this affected portion of piping.
Should we do any additional checks also before replacement of pipe or hardness is OK in this specific case as it's too low? Is there any other reliable method like some sort of heat treatment to increase the hardness of the affected portion?
Need your value comments.
