Dry Gas Seals
Dry Gas Seals
Can anybody share the purpose of tertiary seals in a dry gas seal of compressor?
Re: Dry Gas Seals
Can any one explains the working principle of dry gas seals, its advantages over conventional seals. What type of medium / gasses are used in drygas seals and their significance.
[ t o s i f ]
http://tauseef.engoneer.com
machinedoc
Re: Dry Gas Seals
@tosif
Dry gas seals work on the principle of centrifugal force. Sealing gas is pressurized with the rotation of very tiny impellers of dry gas seal.
Below are some salient benefits of Dry gas seals
1. They are more effective for sealing than the conventional floating oil seals.
2. No seal oil circuit including pumps, tanks and piping are required in dry gas seals.
Normally inert gas like Nitrogen are used for sealing purposes.
@fraz
Tertiary seals are installed for stopping the lube oil flow from bearings into the seals due to the positive pressure of inert gas in it.
@fraz
Re: Dry Gas Seals
Found this very useful presentation on dry gas seal basics.
