Design Calculation for Leak Sealing Clamps
Does someone has the standard drawings of split sleeve clamps used for online leak rectification?
Or any kind of excel / software based design calculations?
Re: Design Calculation for Leak Sealing Clamps
For which type of leakage rectification you want to design a split sleeve clamp?
On flanges / piping?
Qaisar,
If you are talking about a leak sealing clamp for flanges, I can provide you a design calculation sheet in excel.
Please confirm if you want the same.
Octane: I am interested in general clamp designing for both flange & piping.
Ashfaq: Please share the calculations sheet for flanges.
Attached please find an excel sheet for sealing clamp design calculations.
These calculations are for round clamps (split sleeve bolted) used for sealing flange leakages.
Thanks...
Thank you Ashfaq for calculation sheet. Would appreciate if some drawings be also shared.
