Broken shim pack coupling
fraz
Post by fraz »
Is it advisable to keep a shim pack coupling in service with ~5 shims broken out of ~20 shims?
Re: Broken shim pack coupling
Which shim pack couplings are you using?
fraz
Post by fraz »
Its a metastream / Johncrane coupling
Keep looking at the shims regularly at least once a day.
At this point in time, it may not hamper anything but if the looseness or excessive vibration persists, it can fail any time.
