Online Leak Sealing Technique
Can anybody share his experience with online leak sealing technique? who are the renowned vendors whose injectors / sealants are successful in petro-chemical plants for maintenance practices? guidelines / calculations for clamp / box-up designing? any code reference?
Thanks in anticipation of any comment / advise.
Qaisar Abbas
Inspection & Integrity Engineer
Re: Online Leak Sealing Technique
Online sealing technique, as per my experience is very common especially for flange-to-flange leakages. Here is the step wise process:
1. A cold clamp is designed in two pieces considering the design pressure and design temperature of line
2. Clamp contains internal grooves (two) which come on flange body (either sides)
3. Grooves are for sealing; rope like gasket is placed inside
4. Clamp is joined by two bolted plates at their ends
5. After mounting the clamp, a sealant / injector is injected at 1.2 - 1.5 times of operating pressure.
Regarding injector / sealant, Furmanite is the most common source being used in petrochemical industry offering many sealant types. See www.furmanite.com.
Hope this would help.
Feel free to ask any further questions.
Dear Ashfak,
Thank you for assistance and sharing step-by-step general procedure. Furmanite has come to know the pioneer of the subject technique. I also contacted them and requested for details of their specific products. Meanwhile, would you please comment on last two parts of my parent question i.e. guidelines for cold clamp (box-up) designing? any code reference?
Hope to hear from you soon.
Regards - Qaisar
Just to have a diagrammatic understanding of my previous reply, follow the link below:
http://www.freepatentsonline.com/4927182.pdf
Also find the attached image of an in-situ installed clamp.
I know few of the guidelines for designing such clamps but do not have the code reference may be in ASME PCC-2, not sure.
Thank you for referring to some more details.
I am pleased to share with the forum that ASME PCC-2 (ASME Post Construction Committee - Repair & Testing of Pressure Equipment and Piping) is found to be the true code reference for guidelines in the subject matter. Section 2 & Section 3 of this ASME PCC-2 (2009 edition) are specifically for "Welded Repairs & Mechanical Repairs".
Collective Wisdom Worked Here ...... Thank You The PertoStreet Admin for providing this platform
See the below link also, it would also help you.
http://www.hse.gov.uk/research/otopdf/2001/oto01038.pdf
nnreddy
Post by nnreddy »
Dear Forum Members,
Please visist the following web page and you get everything about piping,riser and pipline repair.
http://www.perisai.biz/corrosion/index.html
Thanks
NNREDDY
Hello NNREDDY,
Your reffered site is really informative and quite relevant with innovative repair solutions, specially for marine environment.
Thank you for sharing a valuable knowledge. Hope to have your active participaion at forum.
Regards - Qaisar
