Contaminated SS material cleaning
Posted: 01 Sep 2010, 06:15
by kamran
Very often you come across some maltreated SS material. The contamination could be due to contact with CS or may be due to sandblasting with Chloride-laden sand etc.
What is the most viable way to clean such material remembering that nasty acid baths aren't always a desirable option and in fact not an option at all?
Glass Bead Blasting
Garnet Blasting
Please comment.
Re: Contaminated SS material cleaning
Posted: 01 Sep 2010, 16:42
What's your application?
I do not agree with you that acid cleaning /pickling are not an option. Believe me mechanical cleaning of SS is not effective at all when compared to the advantage of acid treatments.
However, if you just want to go with mechanical cleaning, you then may use glass bead blasting as the first option and then garnet or sand blasting as the second option. You have to consider many precautions when doing blasting operation like the selection of grade and quality of sand / garnet.
Blasting roughens the steel surface which then is less resistive to scale / deposit formation and crevice corrosion.
Posted: 01 Sep 2010, 17:25
Contamination of SS with CS or blasting - the best solution is acid treatment /passivation
Mechanical cleaning again on already blasted surface would impair the condition by increasing the surface roughness. I do not recommend.
Posted: 02 Sep 2010, 04:44
by kamran
These are SS air ducts which have already been given a coat of Zinc Phosphate by the contractor which needed to be removed. Bead blasting or Acid Cleaning is not possible at the site.
Posted: 02 Sep 2010, 18:00
What's the extent of contamination and the service severity with respect to corrosion? Have you blasted with chloride containing sand?
Posted: 03 Sep 2010, 23:16
Then the only option left for you is to perform grit or shot blasting with stainless steel media.
Posted: 03 Sep 2010, 23:34
