Blenders/Mixers for liq-liq mixing
omerfarooqi
Post by omerfarooqi »
Can any one explain selection/sizing creteria for blenders/mixers for liq-liq mixing ? i also require references for different vendors.(pakistani preferable)
Re: Blenders/Mixers for liq-liq mixing
I have attached a document which is for commercial use but would take you through with the design of liquid-liquid mixer.
Do let me know if you require any other design guideline.
omerfarooqi
Thank you ben it illustrates well about static mixer .. can i get any information for mixers that are installed in tanks for mixing of liquids of two different densities? having propellers etc thanks
ibrahim
Post by ibrahim »
omerfarooqi, if you are talking about agitators, then there is a very useful literature attached in following forum topic...
http://www.thepetrostreet.com/forums/vi ... ?f=8&t=117
These are very handy calculations and give you an idea for both process and mechanical design.
omerfarooqi
Thanks alot Ibrahim.. it helps alot.
