KOD MART - Released
Here you can find FREE Engineering Softwares for your day-to-day working, engineered by professional and experienced team.
How do you rate "KOD Mart"?
You may select 1 option
View results
tosif
KOD MART - Released
Post by tosif »
thePetroStreet team has released their second software after the successful release of WeldShop.
The salient features of our new software KOD MART are:
1. Sizing of horizontal Knock out drum without demister pad
2. Sizing of Vertical Knock out drum without demister pad
3. Easy to use; a handy tool
4. Free support services from thePetroStreet team
5. Elaborated input specifications
6. The output results involve:
-- Vessel Dimensions (I.D and Tangent Length)
-- Critical velocity (Terminal Velocity)
Help file has been included in the package.
Released: 4th July 2010.
Download now >> http://www.thepetrostreet.com/database/kod_mart.zip
moe
Re: KOD MART
Post by moe »
good achievement
tosif
Re: KOD MART - Released
Post by tosif »
Thanks moe.
Check that out and provide us your feedback.
wilson.bibe
Post by wilson.bibe »
Good and simple to use it, Many Thanks
bilalanwer
Post by bilalanwer »
love the interface..very user friendly.congratulation team PetroStreet you have done an amazing job.
sharjeel
Post by sharjeel »
Very smart and user friendly software.. Congratulations on fulfilling the promise
Can you please describe the design code that has been followed in the design of this KOD software?
Imran.Idris
Post by Imran.Idris »
Dear forum member, the software has been designed as per calculation guidelines given in API-521.
Qaiser
Post by Qaiser »
Good Going Petrostreet!!!
usmanmk
Post by usmanmk »
tosif,
Great user friendly software. Really appreciates your efforts on the launch of the software.
It would be really better if you can give units of gas in Nm3 or in KSCFH which are normally being used in the calculation. And give some description in the description note that the gas flows are on dry basis.
Great Job
UMK
tosif
Post by tosif »
Thanks guys,
And yes usmanmk, we are working on the unit conversion module, embedded in next version, Insha Allah. Other versions will also cover three phase separation and better dimensional results. We appreciate your valuable comment.
