Allowable Stress Comparison EN13445
When comparing allowable stress as in EN13445 to what is ASME Div. 1, what are the major differences?
Guest
Re: Allowable Stress Comparison EN13445
Actually it is ASME having higher safety factor applied to the allowable stress values.
ghs-21,
Each of the Codes including ASME Div. 1, Div. 2 & EN13445 utilizes a 1.5 design margin on material yield strength. However, the design margin on ultimate tensile strength becomes progressively smaller for
each of the Codes – 3.5 for Division 1, 3.0 for Division 2, and 2.4 for EN 13445. This difference is generally the key factor in explaining why the highest allowable stresses are found in the EN Code,
and the lowest are found in ASME Section VIII Division 1.
Another important point in this comparison is that the EN 13445 Code only considers the ultimate tensile strength of the material at ambient temperature (68°F, or 20°C), whereas the criteria used for allowable stresses in both of the ASME Codes consider the tensile strength at design temperature. This difference can be significant for materials which have yield strengths that remain relatively high at elevated temperatures, such as Cr-Mo steels. When combined with the higher design margins on tensile strength in the ASME Codes, this approach can create a situation where an allowable in the EN Code is based on yield strength, yet the corresponding allowable in both of the ASME Codes at the same temperature is based on tensile strength. In such cases, the EN Code’s yield based allowables significantly exceed the ASME’s tensile based values.
Guest
Thanks irish
