Gas turbine air filtration systems are critical because turbine compressors are extremely sensitive to airborne contaminants — even small amounts of dust, salt, or moisture can cause compressor fouling, erosion, corrosion, or foreign object damage to blades, which directly hits efficiency and mechanical integrity. Here's how the system is typically built up.
## Purpose
The intake air filtration house (often called the "filter house" or "inlet air filtration system") conditions ambient air before it enters the compressor. It needs to remove:
- Dust and particulates (sand, dirt)
- Salt (critical in coastal/offshore environments like the Gulf)
- Moisture/water droplets
- Insects, foreign debris
- Sometimes ice (in cold climates) or oil mist (near process units)
## Major Components (typically arranged in stages, from air inlet to compressor)
**1. Weather louvers / hoods**
First line of defense — knock out rain, large debris, and reduce direct wind-driven moisture ingress.
**2. Inertial separators / vane separators** (common in offshore/desert installations)
Use centrifugal/inertial force to separate coarse dust and water droplets before the air reaches the finer filter stages. Very common in GCC/Middle East plants due to sand ingestion risk.
**3. Pre-filters (first stage)**
Coarse filtration — typically panel or bag filters rated around G3–G4 (or MERV equivalent), removing larger particulates and extending the life of downstream fine filters.
**4. High-efficiency filters (second stage)**
Usually cartridge or bag-type filters, rated F7–F9 or higher (sometimes HEPA-grade for sensitive units), removing fine dust and salt particles down to a few microns. This is the main filtration stage protecting compressor blades from fouling/erosion.
**5. Moisture separators / coalescing filters**
Remove entrained water droplets, especially important in humid or coastal environments — prevents water ingestion causing blade erosion or icing downstream.
**6. Anti-icing system** (climate-dependent)
For cold environments, bleed air or electric heating elements prevent ice formation on the filter media, which could otherwise block airflow or shed ice into the compressor.
**7. Silencers/attenuators**
Not filtration per se, but usually integrated into the same ductwork to reduce inlet noise.
**8. Bypass/self-cleaning provisions**
Many modern filter houses use pulse-jet self-cleaning (compressed air pulses that clean cartridge filters in place) to extend service intervals and manage differential pressure buildup.
**9. Differential pressure (DP) monitoring**
Instrumentation across each filter stage to track fouling — rising DP signals the need for cleaning/replacement, and excessive DP can choke compressor inlet flow, hurting performance and even triggering trips.
**10. Trash/screen guards and bird screens**
Prevent large foreign objects, birds, or debris from reaching the filter media.
## Inspection-relevant angle
From an inspection engineering standpoint, key concerns are:
- Differential pressure trending across filter stages (early fouling detection)
- Filter house structural integrity (housing corrosion, gasket/seal degradation allowing bypass leakage — a big issue because unfiltered air can bypass straight to the compressor)
- Salt deposition and pitting on internals in coastal sites
- Anti-icing system functionality checks before winter
- Ductwork and expansion joint integrity downstream of the filter house
