Centrifugal Pump Seal Failures
A centrifugal pump has experienced three mechanical seal failures within six months.
How would we determine whether the root cause is hydraulic, mechanical, operational, or installation related?
Re: Centrifugal Pump Seal Failures
Three mechanical seal failures within six months should be treated as a reliability problem, not simply a seal problem. Replacing the seal repeatedly without identifying the underlying cause almost always leads to further failures. A structured Root Cause Analysis should separate the causes into hydraulic, mechanical, operational, and installation categories.
Yes that is what we have initiated now and looking for the leads.
