Low Cycle Ratio - Methanol Synthesis Reactor
Posted: 03 Jul 2026, 09:35
by opo21
What is the effect of low recycle ratio on methanol synthesis reactor? How to predict that and the ways to avoid?
Re: Low Cycle Ratio - Methanol Synthesis Reactor
Posted: 08 Jul 2026, 15:04
by tuan
A low recycle ratio may initially appear beneficial because the higher reactant partial pressures can increase the instantaneous reaction rate. However, the loss of thermal buffering and reduced loop circulation usually lead to higher catalyst hot-spot temperatures, poorer overall loop efficiency, increased purge losses, faster catalyst deactivation, and a greater risk of compressor instability. The best practice is to detect the condition early by trending the recycle-to-fresh gas ratio together with reactor temperature profiles, synthesis gas composition, compressor performance, and methanol production. Maintaining recycle flow close to the design value is generally one of the most effective ways to maximize catalyst life, production, and synthesis loop stability.
Posted: 10 Jul 2026, 13:14
by jeem
To avoid that, maintain recycle compressor health, monitor compressor efficiency, vibration analysis, performance testing, seal condition monitoring.
Then optimize purge control, avoid excessive purge while maintaining inert gas limits.
Maintain accurate flow measurement; perform regular calibration of recycle flow transmitters. Fresh gas flow transmitters prevents false recycle ratio indications.
Monitor catalyst condition; increasing pressure drop or higher hot spots often indicate catalyst ageing.
Posted: 14 Jul 2026, 08:05
by sys1
APC is the right way to maintain recycle ratio, reactor temperature profile, synthesis loop pressure, and purge optimization.
