SIL-2 Shutdown Loop
Posted: 21 Jun 2026, 12:03
by ww2i
A SIL-2 shutdown loop has experienced several spurious trips. Would you modify proof test intervals or redesign the architecture? How would you decide?
Re: SIL-2 Shutdown Loop
Posted: 22 Jun 2026, 07:51
by jeem
The first step is to understand whether the issue is related to:
Random hardware failures
Systematic/design issues
Proof test induced errors
Process/environmental conditions
Common cause failures
Poor instrument selection or installation
The decision should be based on a structured review. I would be immediately change the proof tests interval or redesign the architecture.
Posted: 24 Jun 2026, 12:50
by ivani1
If reliability data shows the SIL-2 target is already being achieved but availability is suffering, I would generally favor architecture optimization (e.g., voting logic, diagnostics, redundancy) over simply shortening proof test intervals. This approach usually reduces nuisance trips while maintaining the required SIL.
Posted: 29 Jun 2026, 10:22
by ww2i
Explain me what sort of architecture optimization would you apply?
Posted: 09 Jul 2026, 09:35
by ivani1
It can be in the form of sensor voting, redundancy of final element, applying better diagnosis, or segregating process trips from instrument faults.
Posted: 16 Jul 2026, 14:41
by ww2i
So proof test interval should not be the first thing to do rather looking into voting, redundancy should be given a priority?
