Triangular & square layouts in heat exchangers
Posted: 03 Jun 2026, 14:41
by ivani1
Some mechanical design engineer if can explain the advantages of using triangular /square tube layouts in heat exchangers?
Re: Triangular & square layouts in heat exchangers
Posted: 05 Jun 2026, 06:30
by irish
Some of the factors here include higher heat-transfer efficiency with triangular arrangement; this staggered arrangement creates more turbulence on the shell side, which improves mixing and increases the shell-side heat-transfer coefficient. Then comes more tubes in the same shell diameter; because the tubes are packed more closely, a triangular layout can accommodate a greater number of tubes for a given shell size, increasing heat-transfer area. We may end up in a smaller exchanger for the same duty. The improved heat transfer often allows a smaller shell diameter and lower material cost for a given thermal duty. You can count on better resistance to shell-side fouling in some services. Higher turbulence can reduce deposition tendencies in certain applications.
Then with square layout, we have easy shell-side cleaning; straight cleaning lanes exist between tubes, allowing mechanical cleaning methods such as hydroblasting or rodding. We can hev lower shell-side pressure drop, the more open flow passages reduce resistance to flow. This is normally preferred for fouling services; suitable when solids, sludge, or heavy deposits are expected on the shell side. Reduced risk of flow-induced vibration in some cases just as lower cross-flow velocities can help mitigate vibration issues.
Posted: 06 Jun 2026, 10:37
With triangular tube layout, it is difficult to mechanically clean the shell side because there are no straight lanes between tubes. We have higher shell-side pressure drop due to increased turbulence and less suitable for very dirty shell-side services that require frequent cleaning.
They are good for clean or moderately clean fluids with high heat-transfer duty services.
Square layout offers lower heat-transfer coefficient because the flow is less turbulent. Fewer tubes fit in the same shell diameter and often requires a larger exchanger for the same thermal duty.
Posted: 09 Jun 2026, 14:49
See the general rule of thumb here is that you choose triangular pitch when thermal performance and compactness are the priorities and the shell-side fluid is relatively clean.
Choose square pitch when shell-side fouling and ease of maintenance are the dominant concerns.
Posted: 13 Jun 2026, 09:30
by neo
There is a rotated square 45 deg layout as well. This arrangement:
It helps in:
Maintains cleaning lanes.
Provides somewhat better heat transfer than 90° square pitch.
Often considered a compromise between triangular and square layouts.
Posted: 13 Jun 2026, 10:05
by sys1
Keep the image saved in your mobile.
Posted: 18 Jun 2026, 18:57
wow, amazing
sys1 wrote: 13 Jun 2026, 10:05
Posted: 18 Jun 2026, 19:16
by ivani1
Value all the replies.
Posted: 20 Jun 2026, 09:59
by sys1
The images help a lot to remember.
octane wrote: 18 Jun 2026, 18:57
wow, amazing
