Turbulent flow identification across a heat exchanger
Process engineers,
How can one know if the flow across the tubes of a heat exchanger is turbulent in nature?
Point me towards the reliable engineering calculations /equations to estimate that.
Re: Turbulent flow identification across a heat exchanger
Reynolds number is the key here;
Once you calculate Re:
Re < 100 Laminar (very rare in shell side unless viscous fluid)
100 < Re < 1000 Transition
Re > 1000–2000 Turbulent crossflow
What is your intent?
Why are you worried about turbulence?
I am asking with reference to the vibrations, and erosion happening on the inlet & exit of the heat exchanger piping elbows. All what our Process Engineers are saying is that there hasn't been any issue on their side.
You need to know:
There is NO universal Reynolds number limit for vibration
Turbulence is usually DESIRED - note this
The real limit is critical velocity vs actual velocity
Therefore, you may need to look into:
Reducing baffle spacing
Increasing tube support
Using rod baffles / helical baffles
Adjusting tube pitch
Adding impingement plates
And all this during design phase
Now in case you doubt anything not considered during design, all you need to is to approach design process engineer for heat exchanger, and piping /structure engineer for where you are experiencing vibrations.
