Pitting Corrosion & Chemical Spill @ Freedom Industries (2014)
There has been a lot to learn from the chemical spill happened in Freedom Industries during 2014.
Pitting corrosion attack on the storage tank led to all this causing one of the major process safety incident having environmental impact.
Re: Pitting Corrosion & Chemical Spill @ Freedom Industries (2014)
Can you please share some more details?
If you attached something, sorry could not find that...
jeem wrote: 28 Apr 2026, 17:31 Can you please share some more details?
This writeup may help:
In January 2014, a major chemical spill occurred near Charleston, West Virginia, when approximately 10,000 gallons of 4-methylcyclohexanemethanol (MCHM) leaked from a storage tank at Freedom Industries. The chemical entered the Elk River, contaminating the water supply for ~300,000 residents.
The root mechanical failure was traced to severe pitting corrosion in the tank bottom, which led to through-wall penetration and loss of containment.
Role of Pitting Corrosion (What Actually Happened)
The storage tank (Tank 396) had been out of active service inspection programs for years.
Localized pitting corrosion developed on the tank floor due to:
Water ingress and phase separation
Poor drainage and stagnant conditions
Lack of internal coating integrity
Unlike uniform corrosion, pitting created deep, highly localized penetration, making it difficult to detect without targeted inspection.
The tank bottom eventually failed at a pit location, causing an uncontrolled leak.
Key insight:
Pitting corrosion doesn’t reduce thickness evenly — it creates hidden failure points that can bypass traditional thickness monitoring strategies.
Critical Failures Identified
1. Asset Integrity Breakdown
No routine inspection or RBI (Risk-Based Inspection) applied to the tank
Tank was considered “inactive” but still contained hazardous chemicals
No ultrasonic or floor scanning inspections conducted
2. Poor Understanding of Degradation Mechanisms
No recognition that water + stored chemical = corrosion risk
No corrosion monitoring or mitigation strategy
3. Secondary Containment Failure
The containment dike was:
Cracked and permeable
Not capable of holding leaked material
Result: chemical escaped into the environment
4. Weak Regulatory Oversight
Facility fell outside stricter federal regulations (regulatory gap)
Lack of enforcement for above-ground storage tanks
5. Emergency Response & Communication Gaps
Delayed public notification
Limited understanding of chemical toxicity
Inadequate crisis preparedness
Lessons Learned (Leadership & Operational Focus)
1. “Idle” Equipment Is NOT Risk-Free
Even non-operational assets can fail catastrophically if:
They contain chemicals
They are exposed to environmental degradation
Lesson: Include all equipment (active or idle) in integrity management programs.
Storage had been out of service since years.
A lot to be thought into and done with the decommissioned, and mothballed units.
ivani1 wrote: 29 Apr 2026, 17:38
Key insight:
Clear, thanks.
Key insight:
Thank you ivani1, some very good points.
