Counter Weights - Thermal Expansion System @ Furnace
Re: Counter Weights - Thermal Expansion System @ Furnace
Abbas,
It's a good document.
I do not know to which extent this article will help you.
See attached file.
Yes, this is quite helping article as far as next revamp of our primary reformer is concerned. We are thinking on the same lines and thus engaged a consultant for:
- Replacing counterweight system with constant spring support system
- Upgrading metallurgy of Catalyst tubes from HP-modified to Microalloy
- Changing staggered arrangement to in-line tubes pattern
- Adding new pre-mix burners
Thank you Mechcolor ! Appreciate your knowledge sharing.
