Re: smoke bomb test for furnace casing
Posted: 14 Oct 2010, 05:07
This test is conducted for those exchangers / equipment where other types of leak tests are impractical.
Like you can perform this test for exchangers in the convection section of furnace for detection of any leakage in them as performing any other test even visual is not an easy task. This test just in few minutes finds you the leakage if any.
sakib321 wrote:on our plant side almost all kind of exchanger are present.
so is it possible that we will use this test to detect the leaks in heat exchanger if yes then how???
