TUBE, TUBE SHEET ANALYSIS, TUBE TO TUBE SHEET JOINT
Re: TUBE, TUBE SHEET NALYSIS, TUBE TO TUBE SHEET JOINT
Sohail,
I agree with mechcolor. In addition to what he has said, you may look for any of the books on heat exchanger.
Meanwhile, I will try to provide you the best I can.
Hello again,
See the link below if that helps.
http://www.authorstream.com/Presentatio ... owerpoint/
SOHAIL CHAUDHRY
Post by SOHAIL CHAUDHRY »
Thanks to Ashaf bhai, Ben & Mechlor for your suuport i have gone through manual calculations & TEMA, feel quite better than before.AEM, AEU but still feeling not confident on special type heat exchangers (hairpin) for flaoting head/tube sheet heatexchanger. i am looking for drawing or small catalogs/booklets for above heat exchangers.
You are welcome.
I will look for some mechanical drawings of floating head heat exchangers for you.
Is that what you want?
SOHAIL CHAUDHRY
Yes Ashfaq bhai, i need some mechanical drawing of floating head, double pipe, hairpin heat exchanger because in TEMA you can just view a sketch. Thanks alot.
Sohail,
I have attached a detailed mechanical drawing of BES type heat exchanger.
See if this helps you out.
