To consider having check valves as IPL, we have a requirement that if they are dual and dissimilar then credit can be taken with PFD, 0.1.
What exactly does that mean? They have to be two and must be of different types?
Dual dissimilar check valves
Re: Dual dissimilar check valves
During one of the training session I remember on LOPA and HAZOP, there has to be two different types of check valves to take the credit.
Otherwise, with a single check valve arrangement, credit cannot be taken.
Like you have one swing check, then the other is required to be of wafer type.
Yes, the type of check valve itself should be of a different type and there must be two to avoid the reverse flow.
This how during LOPA a credit can then be taken.
