Mandatroy heat exchangers tube inspection
Guest
Post by Guest »
is there any mandatory guideline document telling us about heat exchangers tube internal inspection with specific NDT methods?
novice123
Re: Mandatroy heat exchangers tube inspection
Post by novice123 »
There is generally not one universal code saying “every heat exchanger shall have X% of tubes inspected by method Y.”
The applicable NDT method and extent depend on tube material, damage mechanism, exchanger configuration, service, previous inspection results, and the required inspection effectiveness.
Dlew
Post by Dlew »
Exchangers tube inspection is an added cost and it is applied only when risk based inspection asks for that.
For selection of appropriate NDE methods, you can refer to Section 1 of API 586.
