Centrifugal Pump Seal Failures
Dlew
Post by Dlew »
A centrifugal pump has experienced three mechanical seal failures within six months.
How would we determine whether the root cause is hydraulic, mechanical, operational, or installation related?
sys1
Re: Centrifugal Pump Seal Failures
Post by sys1 »
Three mechanical seal failures within six months should be treated as a reliability problem, not simply a seal problem. Replacing the seal repeatedly without identifying the underlying cause almost always leads to further failures. A structured Root Cause Analysis should separate the causes into hydraulic, mechanical, operational, and installation categories.
