Detecting drifting transmitters
Instrumentation, PLC, DCS, Control systems, Electric motors, VFDs, Cabling, etc.
ww2i
Post by ww2i »
How do you detect drifting transmitters before they begin affecting process reliability?
sys1
Re: Detecting drifting transmitters
Post by sys1 »
Detecting instrument drift before it impacts process reliability is one of the hallmarks of a mature reliability program.
The objective is to identify gradual degradation before the transmitter reaches its calibration tolerance or causes false alarms, poor control, or spurious trips.
The most effective approach is to combine process analytics, instrument diagnostics, and risk-based maintenance rather than relying solely on periodic calibration.
opo21
Post by opo21 »
The strongest reliability programs use multiple layers:
Continuous online diagnostics from smart transmitters.
Historian trend analysis with statistical tools (EWMA, CUSUM, moving averages).
Cross-validation using redundant instruments and mass/energy balances.
Asset management systems to trend "as-found" calibration data rather than just pass/fail results.
Risk-based calibration intervals, shortening intervals for devices with recurring drift and extending them for stable instruments.
Predictive analytics or digital twins for critical measurements, particularly in high-consequence control and safety applications.
By combining these techniques, plants often identify transmitter drift weeks or months before it causes poor control, false alarms, product quality issues, or spurious shutdowns, significantly improving both process reliability and maintenance efficiency.
tuan
Post by tuan »
Operations troubleshooting at the same time is very important once there are any faulty indications from instrumentation.
Manual intervention, communication with field operator, having the right assessment in time are some important factors.
luca
Area of interest: Electrical Engineering
Post by luca »
Asset management software helps in picking up the following parameters:
Calibration history
Device diagnostics
Failure history
Drift rate
Sensor health
Environmental conditions
They can predict like, "This pressure transmitter will exceed calibration tolerance in 4 months."
This is predictive maintenance rather than reactive maintenance.
ww2i
Post by ww2i »
luca, can you please share with me some examples of such systems?
luca wrote: 08 Jul 2026, 15:09 Asset management software helps in picking up the following parameters:
Calibration history
Device diagnostics
Failure history
Drift rate
Sensor health
luca
Post by luca »
These are some of the few ones:
1. AMS Device Manager
Plants with Emerson instrumentation
Device diagnostics, calibration records, predictive alerts, valve diagnostics
2. FieldMate
Yokogawa-based plants
Device configuration, diagnostics, offline/online maintenance
3. FieldCare
Endress+Hauser instruments
Instrument health, parameter management, calibration support
4. PACTware
Multi-vendor environments
Universal FDT/DTM platform supporting many manufacturers
5. SIMATIC PDM
Siemens automation systems
ww2i
Post by ww2i »
Thanks luca
