Chemical Composition of 15NiCuMoNb5
Can somebody please tell me the chemical composition of 15NiCuMoNb5?
Re: Chemical Composition of 15NiCuMoNb5
Min. Max.
Carbon 0.170
Manganese 0.8000 1.200
Silicon 0.2500 0.500
Phosphorus 0.030
Sulfur 0.025
Aluminum 0.0150
Chromium 0.300
Copper 0.5000 0.800
Molybdenum 0.2500 0.500
Columbium (Niobium) 0.0150 0.045
Nickel 1.0000 1.300
Nitrogen 0.020
Carbon 0.170
Phosphorus 0.030
Sulfur 0.025
Aluminum 0.0150
Chromium 0.300
Copper 0.5000 0.800
Nickel 1.0000 1.300
Nitrogen 0.020
Thanks Ashfaq.
By the way, I know this is a pressure plate, do you know where is it used normally?
sadia.shahab
15NiCuMoNb5 is normally used for steam drums & seamless boiler tubes upto 500°C. Max. thickness in case of plate is 300mm.
Yes, Sadia is right. Its basically a low alloy steel plate used for pressure vessels at increased temperatures.
Thanks everybody for the inputs.
ASTM No for above material?
sadia.shahab
There is no ASTM equivalent for 15NiCuMoNb5.
Following ASTM materials may be considered as an equivalent of 15NiCuMoNb5 steel.
ASTM A302 Gr. B
ASTM A302 Gr. C
ASTM A508 Gr. 2
ASTM A508 Gr. 2A
ASTM A508 Gr. 3
ASTM A508 Gr. 3A
ASTM A533 Gr. B
ASTM A533 Gr. C
ASTM A533 Gr. D
These matches are given by AWSTEELS (Atlas of World Steels and Alloys) program.
ASTM A302 Gr. B
ASTM A302 Gr. C
ASTM A508 Gr. 2
ASTM A508 Gr. 2A
ASTM A508 Gr. 3
ASTM A508 Gr. 3A
ASTM A533 Gr. B
ASTM A533 Gr. C
ASTM A533 Gr. D
