Predicting fouling in heat exchangers
Operational issues of any Petrochemical plant or Oil and gas field, upstream issues, etc.
irish
Post by irish »
What operational indicators best predict fouling in heat exchangers before performance loss becomes severe?
sys1
Re: Predicting fouling in heat exchangers
Post by sys1 »
A gradual rise in differential pressure is one of the best early indicators.
Deposits reduce flow area:
tube-side fouling leads to higher tube velocity resulting in ΔP rises
shell-side fouling leads to shell restriction increases
Sometimes duty still appears acceptable because operators compensate elsewhere, but ΔP starts drifting first.
Better trend:
ΔP/day
ΔP normalized to flow
ΔP at constant throughput
Do NOT compare raw ΔP blindly during rate changes.
Strong leading sign: A slow but persistent rise over weeks is more meaningful than short spikes.
tuan
Post by tuan »
Take it with rising approach temperature which is a very useful indicator.
For coolers: Approach = Process outlet temp − Cooling medium inlet temp
For heaters: Approach = Heating medium outlet temp − Process inlet temp
When fouling develops heat transfer coefficient drops, and exchanger loses thermal efficiency.
It often detects thermal resistance before total duty collapse.
Operations teams sometimes miss this because overall outlet temperatures still remain “within target.”
opo21
Post by opo21 »
This depends if the problem is recurring and critical in nature where isolatio may not be possible all the times. There you switch the program to all predictive mode of identifying fouling.
That paticular program combine historian trends, operator observations, RBI data, corrosion monitoring, vibration
infrared scans, chemistry data; instead of relying on thermal performance alone.
ivani1
Post by ivani1 »
The service related parameter is required to be identified and picked to predict any fouling in heat exchangers.
Like for cooling water exchangers, ΔP rise; Crude preheat exchangers, temperature cross deterioration; steam heaters, steam valve opening trend; air coolers, fan/power increase + approach temp; slurry services, rapid ΔP increase; polymer fouling services, control instability; vacuum system, loss of condenser effectiveness and for reactor feed effluent exchangers, U-value decline.
This would be providing some reliable trending & predicting.
