Identification of drillstring tool failure
Operational issues of any Petrochemical plant or Oil and gas field, upstream issues, etc.
opo21
Post by opo21 »
Identifying drillstring or downhole tool failures early is critical because the first subtle signs often appear at surface before a catastrophic event like a twist-off, stuck pipe, or BHA loss occurs. What are the good practices here to identify that well in time?
tuan
Re: Identification of drillstring tool failure
Post by tuan »
Monitor surface parameters first which are the early warning signs.
Key indicators to watch include:
1. Torque Changes
Sudden increase > possible tight hole, tool damage, differential sticking
Sudden drop > tool joint failure, twist-off, connection failure
2. Weight on Bit (WOB) Abnormalities
Inconsistent WOB transfer
Weight not reaching bit > pipe stretch or mechanical failure
Unexpected slack off
3. Standpipe Pressure Changes
Pressure drop > washout, leak in drillstring
Pressure increase → plugged bit nozzles, solids accumulation
4. RPM & Vibration
Erratic rotation > BHA instability or motor failure
Stick-slip vibration > tool fatigue risk
jeem
Post by jeem »
Suspect tool failure if you observe:
Sudden torque drop
Unexplained pressure drop
Erratic WOB transfer
Sudden ROP change
Abnormal vibration
Loss of telemetry
Mud leakage at surface
Monitoring of these 7 parameters would help.
opo21
Post by opo21 »
Appreciate all the inputs.
