Operational controls - steam condensate circuit
Operational issues of any Petrochemical plant or Oil and gas field, upstream issues, etc.
irish
Post by irish »
What are the normally controlled parameters in steam condensate circuit to avoid erosion-corrosion phenomena?
opo21
Re: Operational controls - steam condensate circuit
Post by opo21 »
Yes, pH is controlled, dissolved oxygen as well, and conductivity.
Erosion-corrosion is accelerated due to high flows and that is what is measured separately when the damage phenomenon is happening.
tuan
Post by tuan »
The parameters which are required to be controlled for erosion-corrosion phenomenon mainly include the flow (velocity), and the temperature.
Dissolved oxygen would also cause pitting corrosion.
Identify closely the kind of damage mechanism which is currently on.
jeem
Post by jeem »
Yes, opo21 and tuan have listed most of the things which are on a regular check.
It is better just to have component level identification of flow especially where there is a problem being identified on frequent basis.
irish
Post by irish »
Operations, may not be the right people to answer this but any thoughts when we just keep on replacing the problematic piping components with austenitic stainless steel?
jeem
Post by jeem »
Now, this has to be answered by our materials guys.
irish wrote: 03 Jan 2026, 19:23 Operations, may not be the right people to answer this but any thoughts when we just keep on replacing the problematic piping components with austenitic stainless steel?
Though I have seen that happening, and have always condemned that.
Moving straight to ASS from normal CS piping to avoid erosion is no technical or commercially viable solution.
There are other many materials on the way which can resist this erosion-corrosion phenomenon.
In my opinion, material upgrade is only recommended once through studies, sessions, it is agreed with all other disciplines that any mitigation to control ongoing erosion-corrosion is not helping.
opo21
Post by opo21 »
In that case, what are the recommended materials to be upgraded with?
mechcolor wrote: 15 Jan 2026, 18:56 Though I have seen that happening, and have always condemned that.
Okay, so you just need to start with the basic ingredient to avoid such issues in steam condensate piping.
Just C-0.5Mo itself would help eliminate this.
Using SS piping elbows /reducers /tees would be an overkill.
