Welding Cost
novice123
Welding Cost
Post by novice123 »
Does anybody have any workable sheet on doing the piping welding job cost estimation?
That would help.
ivani1
Re: Welding Cost
Post by ivani1 »
If you are looking for a sheet only to understand all the concepts within the cost calculation then I may have to search for that in my database, must be having.
However for some calculations which may provide you with normally required outcome like quantity & cost of consumables, you may try to use the following link:
https://welding-calculator.voestalpine.com/en/dashboard
Dlew
Re: Welding Cost
Post by Dlew »
Such a welding cost calculator is offered by ESAB as well.
That is an online tool called QWPA, Quick Welding Productivity Analyzer.
Re: Welding Cost
Attachment size hurts. Got 1.5 MB welding cost calculator (excel based) with all featured pipe sizes & other details to input.
Re: Welding Cost
Okay check this sheet now.
Got rid of some sheets within keeping the calculations for fillet weld joint along with V-Groove.
Hope this helps.
L_Weld-Cost-Calculation.xls
novice123
Re: Welding Cost
Post by novice123 »
The resource helped, arcpro.
So you were having other weld joint details as well in other sheets?
Check if you can share that separately as well.
