WeldPulse - Welding Software
Latest developments and modifications on forums
PetroStreet
Site Moderator
Post by PetroStreet »
WeldPulse Intro Video: https://www.youtube.com/shorts/HKwA_UAwZSA
WeldPulse is planned for its re-release shortly.
Meanwhile, have a look at a self-explanatory video on Welding Processes which is part of TrainMe! module of WeldPulse.
https://youtu.be/WhgNI7aL2B4?si=quj1GlI_eapLqtrC
PetroStreet
Site Moderator
Re: WeldPulse - Welding Software
PetroStreet
Site Moderator
Video (3/10): Welding Positions
https://youtu.be/A3pggj0AqeE?si=O6Wg5HzMRsO7KDAU
PetroStreet
Site Moderator
And the critical update is that WeldPulse Software will be available in maximum three weeks time from now.
PetroStreet
Site Moderator
WeldPulse Software
Welding | Procedure | Ready
Available to download & buy!
https://www.WeldPulse.com
PetroStreet
Site Moderator
WeldPulse features include the following:
1. QuickWeld module (Ready to qualify details for a welding procedure)
2. WPS (Archiving & retrieving forms) - Arc Edition only
3. PQR (Archiving & retrieving forms) - Arc Edition only
4. Material Properties (Necessary welding properties of materials)
5. Filler Properties (Necessary properties for filler & electrodes)
6. Procedure Qualification - Pro-IX (Essential variables for procedure qualifications)
7. Performance Qualification - Welder-IX (Essential variables for performance qualifications) - Arc Edition only
8. Welding Calculator (Welding Cost, Predict-F - Ferrite Check, Carbon Equivalent, Heat Input) - Arc Edition only
Get your copy here:
PetroStreet
Site Moderator
Brochure.
PetroStreet
Site Moderator
Some mandatory guidelines about the software once you download it.
https://www.scribd.com/document/8966097 ... Guidelines
PetroStreet
Site Moderator
Welding Cost & Economy Calculations with WeldPulse Software.
Explained in detail as how to use the software:
https://www.scribd.com/document/9053759 ... l-Settings
PetroStreet
Site Moderator
Welding Austenitic Stainless Steel, SA312 304 to Duplex Stainless Steel Pipe, SA790 S31500.
Welding_Austenitic_Stainless_Steel_to_Duplex_Stainless_Steel.pdf
