Pressure Design Thickness Calculation as per B31.4 & B31.8
Has anybody excel sheet for calculation of pressure design thickness of pipe as per B31.4 and B31.8?
Re: Pressure Design Thickness Calculation as per B31.4 & B31
See if attached files help.
irish
Post by irish »
Useful sheets.
Thanks Ashfaq.
Thanks for sharing.
novice123
Post by novice123 »
I need few clarifications regarding Pipelines
1) Why is it economical to transport gas at the lowest temperature possible?
2) Why Stress problems in low temp gas pipelines are less severe than that in an oil line?
novice123
Post by novice123 »
Any thoughts regarding above clarifications.
It varies from case to case. Not always the transportation of gas at lower temperature is economical. It primarily depends upon the climatic conditions of the area where gas is being transported.
Stresses in pipelines are mainly due to the internal pressure and temperature conditions. Explain a bit what are you asking for?
novice123 wrote:I need few clarifications regarding Pipelines
