Bolt Torquing Requirement
How can one know the required torque for proper tightening of bolts?
mechaengr
Re: Bolt Torquing Requirement
Post by mechaengr »
Do u need a general data or for a specific equipment or application....?
I need to know about the bolt torquing requirements for flange connections and for steel structures also.
Any help would be appreciated.
1772
Post by 1772 »
From portlandbolt.com
Bolt Torque Chart
Quick Links
Download Print Version
Tension vs. Torque Explained
Concerns Calculating Torque
Suggested Starting Values
The below estimated torque calculations are only offered as a guide. Use of its content by anyone is the sole responsibility of that person and they assume all risk. Due to many variables that affect the torque-tension relationship like human error, surface texture, and lubrication the only way to determine the correct torque is through experimentation under actual joint and assembly conditions.
ASTM A307
Bolt Size TPI Proof
Load (lbs) Clamp
Load (lbs)
Tightening Torque (ft lbs)
Waxed Galv Plain
1/4 20 1145 859 2 4 4
5/16 18 1886 1415 4 9 7
3/8 16 2790 2093 7 16 13
7/16 14 3827 2870 10 26 21
1/2 13 5108 3831 16 40 32
9/16 12 6552 4914 23 58 46
5/8 11 8136 6102 32 79 64
3/4 10 12024 9018 56 141 113
7/8 9 15200 11400 83 208 166
1 8 20000 15000 125 313 250
1 1/8 7 25200 18900 177 443 354
1 1/4 7 32000 24000 250 625 500
1 3/8 6 38100 28575 327 819 655
1 1/2 6 46400 34800 435 1088 870
1 3/4 5 68400 51300 748 1870 1496
2 4 1/2 90000 67500 1125 2813 2250
2 1/4 4 1/2 117000 87750 1645 4113 3291
2 1/2 4 144000 108000 2250 5625 4500
2 3/4 4 177480 133110 3050 7626 6101
3 4 214920 161190 4030 10074 8060
3 1/4 4 255600 191700 5192 12980 10384
3 1/2 4 299880 224910 6560 16400 13120
3 3/4 4 347760 260820 8151 20377 16301
4 4 398880 299160 9972 24930 19944
SAE GRADE 2
Bolt Size TPI Proof
Load (lbs) Clamp
Load (lbs)
Waxed Galv Plain
1/4 20 1750 1313 3 7 5
5/16 18 2900 2175 6 14 11
3/8 16 4250 3188 10 25 20
7/16 14 5850 4388 16 40 32
1/2 13 7800 5850 24 61 49
9/16 12 10000 7500 35 88 70
5/8 11 12400 9300 48 121 97
3/4 10 18400 13800 86 216 173
ASTM A325
Bolt Size TPI Tension Tightening Torque Range (ft lbs) (Min - Max)
Min Max Plain Galv Waxed
1/2 13 12000 14000 100 - 117 125 - 146 50 - 58
5/8 11 19000 23000 198 - 240 247 - 299 99 - 120
3/4 10 28000 34000 350 - 425 438 - 531 175 - 213
7/8 9 39000 47000 569 - 685 711 - 857 284 - 343
1 8 51000 61000 850 - 1017 1063 - 1271 425 - 508
1-1/8 7 56000 67000 1050 - 1256 1313 - 1570 525 - 625
1-1/4 7 71000 85000 1479 - 1771 1849 - 2214 740 - 885
1-3/8 6 85000 102000 1948 - 2338 2435 - 2922 974 - 1169
1-1/2 6 103000 124000 2575 - 3100 3219 - 3875 1288 - 1550
ASTM A449 / SAE GRADE 5
Bolt Size TPI Proof
Load (lbs) Clamp
Load (lbs)
Waxed Galv Plain
1/4 20 2700 2025 4 11 8
5/16 18 4450 3338 9 22 17
3/8 16 6600 4950 15 39 31
7/16 14 9050 6788 25 62 49
1/2 13 12050 9038 38 94 75
9/16 12 15450 11588 54 136 109
5/8 11 19200 14400 75 188 150
3/4 10 28400 21300 133 333 266
7/8 9 39250 29438 215 537 429
1 8 51500 38625 322 805 644
1 1/8 7 56450 42338 397 992 794
1 1/4 7 71700 53775 560 1400 1120
1 3/8 6 85450 64088 734 1836 1469
1 1/2 6 104000 78000 975 2438 1950
1 3/4 5 104500 78375 1143 2857 2286
2 4 1/2 137500 103125 1719 4297 3438
2 1/4 4 1/2 178750 134063 2514 6284 5027
2 1/2 4 220000 165000 3438 8594 6875
2 3/4 4 271150 203363 4660 11651 9321
3 4 328350 246263 6157 15391 12313
ASTM A193 B7
Bolt Size TPI Proof
Load (lbs) Clamp
Load (lbs)
Waxed Galv Plain
1/4 20 3350 2513 5 13 10
5/16 18 5500 4125 11 27 21
3/8 16 8150 6113 19 48 38
7/16 14 11150 8363 30 76 61
1/2 13 14900 11175 47 116 93
9/16 12 19100 14325 67 168 134
5/8 11 23750 17813 93 232 186
3/4 10 35050 26288 164 411 329
7/8 9 48500 36375 265 663 530
1 8 63650 47738 398 995 796
1 1/8 7 80100 60075 563 1408 1126
1 1/4 7 101750 76313 795 1987 1590
1 3/8 6 121300 90975 1042 2606 2085
1 1/2 6 147550 110663 1383 3458 2767
1 3/4 5 199500 149625 2182 5455 4364
2 4 1/2 262500 196875 3281 8203 6563
2 1/4 4 1/2 341250 255938 4799 11997 9598
2 1/2 4 420000 315000 6563 16406 13125
2 3/4 4 468500 351263 8050 20124 16100
3 4 567150 425363 10634 26585 21268
3 1/4 4 674500 505875 13701 34252 27402
3 1/2 4 791350 593513 17311 43277 34622
3 3/4 4 917700 688275 21509 53771 43017
4 4 1052600 789450 26315 65788 52630
ASTM A490
Bolt Size TPI Tension (lbs) Tightening Torque Range (ft lbs) (Min - Max)
Min Max Plain Lubricated
1/2 13 15000 18000 125 - 150 63 - 75
5/8 11 24000 29000 250 - 302 125 - 151
3/4 10 35000 42000 438 - 525 219 - 263
7/8 9 49000 59000 715 - 860 357 - 430
1 8 64000 77000 1067 - 1283 533 - 642
1-1/8 7 80000 96000 1500 - 1800 750 - 900
1-1/4 7 102000 122000 2125 - 2542 1063 - 1271
1-3/8 6 121000 145000 2773 - 3323 1386 - 1661
1-1/2 6 148000 178000 3700 - 4450 1850 - 2225
ASTM A354-BD / SAE GRADE 8
Bolt Size TPI Proof
Load (lbs) Clamp
Load (lbs)
Lubricated Plain
1/4 20 3800 2850 6 12
5/16 18 6300 4725 12 25
3/8 16 9300 6975 22 44
7/16 14 12750 9563 35 70
1/2 13 17050 12788 53 107
9/16 12 21850 16388 77 154
5/8 11 27100 20325 106 212
3/4 10 40100 30075 188 376
7/8 9 55450 41588 303 606
1 8 72700 54525 454 909
1 1/8 7 91550 68663 644 1287
1 1/4 7 120000 90000 938 1875
1 3/8 6 138600 103950 1191 2382
1 1/2 6 168600 126450 1581 3161
1 3/4 5 228000 171000 2494 4988
2 4 1/2 300000 225000 3750 7500
2 1/4 4 1/2 390000 292500 5484 10969
2 1/2 4 480000 360000 7500 15000
2 3/4 4 517650 388238 8897 17794
3 4 626850 470138 11753 23507
3 1/4 4 745500 559125 15143 30286
3 1/2 4 874650 655988 19133 38266
3 3/4 4 1014300 760725 23773 47545
4 4 1163400 872550 29085 58100
Notes:
1.Values calculated using industry accepted formula T = KDP where T = Torque, K = torque coefficient (dimensionless), D = nominal diameter (inches), P = bolt clamp load, lb.
2.K values: waxed (e.g. pressure wax as supplied on high strength nuts) = .10, hot dip galvanized = .25, and plain non-plated bolts (as received) = .20.
3.Torque has been converted into ft/lbs by dividing the result of the formula by 12
4.All calculations are for Coarse Thread Series (UNC).
5.Grade 2 calculations only cover fasteners 1/4"-3/4" in diameter up to 6" long; for longer fasteners the torque is reduced significantly.
6.Clamp loads are based on 75% of the minimum proof loads for each grade and size.
7.Proof load, stress area, yield strength, and other data is based on IFI 7th Edition (2003) Technical Data N-68, SAE J429, ASTM A307, A325, A354, A449, and A490.
Thanks boss.
Is there any calculation for bolting torque on the basis of internal pressure (in case of bolted flanges) or applied load on structural bolts?
1772
Post by 1772 »
Found this info on another web site, hope it helps.....
Pressure x area gives force on all the bolts. Dividing by number of bolts gives force on each bolt. Divide force on each bolt by 0.0200 square inches. (This is the tensile stress area for a #10-32 UNF bolt. One source for this information is the Machinery's Handbook; find one and verify the number I quoted you.) The result is the pressure on each bolt, and needs to be lower than the yield strength of the bolt as a minimum. (Don't use ultimate) How much lower depends on the factor of safety that you are designing with for a high pressure system.
