Oil chalk test for annular plate to shell welding testing
Ahmedfromkuwait
Post by Ahmedfromkuwait »
Aassalam alekum,
I want detail procedure how to conduct oil chalk test for Shell to annular fillet weld checking.
should chalk powder be wet or dry.
where to apply.
weld to be completed first inside or outside.
Detail procedure appreciable.
Khuda hafees,
Ahmed
Re: Oil chalk test for annular plate to shell welding testin
Wa Alaikum Assalam,
The first pass of the weld shall be completed from inside and then the examination must be done for any leakage.
Why do you want to conduct an oil test? Is it a contractual requirement?
1. Complete one pass of inside fillet weld first
2. Remove all the contaminants, dust particles etc. from the inside fillet weld
3. Visually examine the whole circumference of the weld
4. Apply light diesel (we always use that) on the weld joint
5. Apply dry chalk powder on the outside of the annular plate
6. Wait for four hours
7. Start inspecting the whole circumference closely for any leakage
Cautions:
a. Do not apply so dense chalk powder that the diesel may not be able to come up
b. Diesel must be applied properly on the whole circumference of the inside fillet joint
c. Do not make more than one fillet pass inside in order to conduct the test
d. After successful completion of the test, proper cleaning is mandatory so that no weld contamination must take place
Ahmedfromkuwait
yes it is contract requirement.
As per API only one side is to be welded & from other side oil is injected between the gap of annular plate to shell.
Wet or dry chalk poweder is applied.
needs detail procedure
What more details you want to know?
