I am sure this is going to be one big release as you guys released some other utilities, very handy ones, but you never asked for any suggestions. This time it is different from the previous ones.
Can you make this software interact-able with real time values of a running gas turbine /steam turbine? i.e., taking real time values from DCS and showing efficiencies and consumptions in real time? This will be a booster for operating interfaces.
I am sure you will also include HRSG evaluations in it. In case there are two or three steam generators running in parallel, can your software guide in optimum operating parameters for the two steam generators depending upon load?
Can you also include vibration analysis of a steam turbine to diagnose online issues?
Looking forward to the release of the Turbomart
Good luck petrostreet team. May God be with you.
TurboMart - Turbine Performance Evaluator (Released)
Re: TurboMart - Turbine Performance Evaluator (Released)
TurboMart has been released.
Great effort thepetrostreet team.
Unique utility.
Unique utility.
After addressing some critical issues, a revised version 1.0.01b has been released. Issues addressed are;
1- Display error in gas turbine module with exhaust flows.
2- Display error in steam turbine module with induction turbine.
3- Support added for Windows 7 and Vista.
You can download the latest version from the download section.
[ t o s i f ]
http://tauseef.engoneer.com
I could not find this type of software for free. Indeed a great effort!!
Long Live TPS
Long Live TPS
I must say, an excellent work by your team. its no doubt a quick surveillance of turbines, especially gas turbines. thumbs up
Nicole
No doubt its a good software, but how i get the exhaust oxygen composition? or exhaust flow of running gas turbine?
Usually for a running gas turbine routine sample is collected at the exhaust. Sometimes O2 analyzer is also installed at the exhaust stream of Gas Turbine. Usually it runs between 13~16% on dry basis.
At out plant exhaust flow is not measured, however at some plants it is also being measured.
TurboMart help file is attached for your reference.
TURBOMART Ver. 1.0.0b
By: thePetroStreet(c)
Web: http://www.thepetrostreet.com
TurboMart is a unique software with a strong back-end to calculate the efficiencies of your turbines - both steam and gas. Turbines are usually back bone of powerplants and oil & gas industry. Their optimization, efficiency and effectivness is one of the jobs of Process Engineers. TurboMart enables Process Engineers to calculate the efficiency in the most appropriate way by using authentic corelations and industrial practices. It takes the user through every detail and provide him with all the useful data he is concerned with.
LICENSE CONDITIONS:
This is a copyrighted program and intellectual property of thePetroStreet. However, it can be used and distributed free of cost. thePetroStreet does not certify any of its evaluations/ results so use it entirely at your own risk. The program authors give no guarantee that the program is fit for any purpose, and disclaim all liabilities, whether direct or consequential.
Please direct queries to support@thepetrostreet.com in case of licensing issues.
[ t o s i f ]
Satiya
Good software. Are the inputs of oxygen percentage dry basis or wet basis?
