Scan Time for PLC Processors
Instrumentation, PLC, DCS, Control systems, Electric motors, VFDs, Cabling, etc.
ali.abbas
Area of interest: Inst. & Control Engineering
Post by ali.abbas »
Is there any impact on the scan time of a PLC processor when used in a redundant configuration?
If so, can anyone explain why?
Ali Abbas
AbsarShah
Re: Scan Time for PLC Processors
Post by AbsarShah »
No, there shouldn't be an impact when you're using the PLC in FULL REDUNDANT configuration. Depends up to what level you are enforcing the redundancy. If you're using redundant I/O modules but a single processor, then obviously there's going to be an impact on the scan time. But if you use full redundant, meaning redundant I/O modules, plus redundant processor, there shouldn't be an impact at all.
Either way, the PLC vendor will be able to give you a better picture, because many vendors offer in-card redundancy, the scan time in which case will depend on their internal architecture.
ali.abbas
Post by ali.abbas »
My question was regarding a fully redundant configuration, i.e. redundant I/O cards plus redundant processor.
I agree that every PLC has a distinct approach of providing redundancy. In some cases, each processor communicates with the I/O cards independently for updation of data while in the rest, one of the processors (the Primary/Master) communicates with the I/O cards and the other (the Slave/Secondary/Backup) merely copies data from the Primary. There might be other approaches as well, depending from vendor to vendor, of course.
Well the 2 most widely used PLC's I can think of are Allen Bradley Controlgix and Siemens S7. So if somebody can answer with respect to these specific ones it should give a reasonable idea.
Ali Abbas
AbsarShah
Post by AbsarShah »
I think the best people to answer that would be AB or Siemens guys. Just give them a call, vendors are always more than happy to help.
